Barge Engineer
Plavi9
As per phone conversation kindly be advised that we require a barge engineer for a one off hitch on a cold stacked rig.
The hitch might be long up to 7 weeks.
Please advise if you would be interested in this position.
regards
Noeleen Mallia
Recruitment Officer
Marine House , Dun Karm street c/w Giovanni Mamo street B'Kara Malta
Phone: +356 21424410 Fax: +356 21424405
Home - OMS Offshore Marine Services
Pozdrav,sretno!
regards
Noeleen Mallia
Recruitment Officer
Pozdrav,sretno!
Evo javio sam se, rekla Noeleen da ce proslijedit klijentu cv pa cemo vidjet. Inace ne zna jos nista o poziciji, kad, sto gdje, tek jutros dobili zahtjev od klijenta. Da mi je znat sto se radi na cold stacked rigu.. :rolleyes:
Ne razbijaj glavu s time...imaju dobre kompanije.Ako si mladji i možeÅ¡ riskirati,nećeÅ¡ požaliti.
Ja sam bio preko njih nekoliko puta,ali kako sam ja stariji i ,jednostavno ,nemogu dugo bit doma prihvatio sam drugi posao koji je puno manje plaćen.
Sretno!:)
mail
mail
Na koji si mail posla jeli mozes rec ako nije problem
BARGE ENGINEER is needed to perform an inspection for a drilling swamp barge. If you are suitable and interested, pls send your CV to mets1@mets.sg Thank you.
